Archived
max length text parameter
  • November 7, 2019
  • 70 views
lars_de_vries
Forum|alt.badge.img+10
I'd like to be able to configure the text paramater to set a maximum length.
The use case is quite simple. People have an option to make a remark with a certain workspace. The remark will be added to the dataset in a field. However the field has a maximum of characters allowed. I would like to set this number of characters, so I want have to make the workspace fail if people add to many characters in the Parameter.
rylanatsafe
Forum|alt.badge.img+14
  • November 8, 2019
You are able to setup a workflow to do this (ParameterFetcher --> Tester --> Terminator), but I could see the advantage of putting this logic into the parameter itself, so then a user would be unable to submit a workspace with an invalid string value (e.g. too long)!
Forum|alt.badge.img+54
  • November 9, 2019
Yes, I'd like to see more ability to control what can be entered within certain parameters
https://knowledge.safe.com/idea/43202/add-input-mask-or-similar-to-parameter-types.html
