Released
MapInfoStyler and MapInfo_EXTENDED
Related products:Transformers
  • October 25, 2017
  • 56 views
Hello, i used tne new writer format MAPINFO_EXTENDED and found this writer is not compatible with the transformer MapInfoStyler. Do you plan to update this transformer ?
I also try to set the style by Format Attribute with no succes.
I exposed the attribute mapinfo_pen_pattern, mapinfo_pen_color and mapinfo_pen_width for the destinations Feature Type and add some constant value for this attribute. Nothing change in the output... Any idea ?
Germain
kyrgyzkiwi
  • March 19, 2019
This is still a problem with 2019
mark2atsafe
Forum|alt.badge.img+59
I just found this out myself. It's already filed as an issue with our developers as FMEENGINE-37561. I'm going to add a link to this query so they are aware. I think it's a fairly high priority, but first needs support in a library that is not in our control, so I can't say when it might be implemented. Apologies for any inconvenience this is causing.
ciarab
Forum|alt.badge.img+10
  • October 13, 2020
@mark2safe Do you know what the status is on this. Is it anywhere on the road map for 2021?? As mapinfo users move to EXTENDED its becoming an issue not being able to provide a style with the tab outputs
