Within the MapboxStyler transformer it would be great to have the option of an attribute value in the Marker Symbol option. For instance if my attribute values are integers 0-99, Mapbox can take that number and put it in the marker symbol (ref here:https://github.com/mapbox/simplestyle-spec/tree/master/1.1.0) and basically create a label. Right now the only option is to choose from the marker symbol list and then use StringReplacer for the marker symbol attribute and replace it with the integer attribute value to create that marker
