Open
Making Transformer version history available
Related products:FME Form
dave_seamless
rylanatsafe
debbiatsafe
siennaatsafe
+43
  • dave_seamless
    dave_seamless
  • rylanatsafe
    rylanatsafe
  • debbiatsafe
    debbiatsafe
  • hollyatsafe
  • siennaatsafe
    siennaatsafe
  • nathanatsafe
    nathanatsafe
  • david_r
  • redgeographics
  • hkingsbury
    hkingsbury
  • geomancer
    geomancer
  • danilo_fme
    danilo_fme
  • jdh
    jdh
  • lifalin2016
    lifalin2016
  • sigtill
    sigtill
  • warrendev
    warrendev
  • tcrossman
    tcrossman
  • vxn43
    vxn43
  • j.botterill
    j.botterill
  • connecter
    connecter
  • fgiron
    fgiron
  • kennyo
    kennyo
  • chriswilson
    chriswilson
  • 1spatialmary
  • revesz
    revesz
  • conterraben
    conterraben
  • marcel_conterra
  • mattias
    mattias
  • emeka_domingo
    emeka_domingo
  • cwarren
    cwarren
  • davisblack
    davisblack
  • conterra_chrisc
    conterra_chrisc
  • endest
    endest
  • mbv
  • arnold_bijlsma
    arnold_bijlsma
  • ecthelion
    ecthelion
  • roland.martin
    roland.martin
  • gavinpark
    gavinpark
  • xilef
    xilef
  • geoal
    geoal
  • wicki
    wicki
  • denniswilhelm
    denniswilhelm
  • conterrache
    conterrache
  • turid_skedsmo
  • heisigch
  • raghavendrans
    raghavendrans
  • conterraclara
  • fmeinfoaggregat
  • filipovitz
    filipovitz
It would be nice to get the Transformer version history as a default option in the context menu. If you update a Transformer in FME 2016 you get to see the changes between the different versions that are used but you have to go via the update option and you aren’t able to see all changes. So in case you just want to see what changes occurred to a transformer, you have to find an old version of it to see the changes.
Forum|alt.badge.img+3
Second this! I'd like a grid/overview of the transformer versions and their respective FME Desktop builds. Right now I'm working on a workspace that's been saved in a newer version of FME Desktop, and I'm trying to figure out which transformer versions I have in my version of FME Desktop, and which exist in newer versions of FME Desktop.
As it is now, I can only see version numbers if there's any transformers to upgrade. As I don't have the new transformers in my workspace, I can't see the version numbers. The only way I've found to figure out the transformer version numbers is to open up an older workspace, hope that the transformer in question has been used there, find it under "Upgradable transformers", and then look at the version numbers there.
mark2atsafe
Forum|alt.badge.img+44
  • February 8, 2017
@turid_skedsmo - Look under Tools > FME Options > Transformers. There is an option there to display the transformer version. When you do that it appears in pop-ups and summary annotation. That would probably solve a lot of the issues you are having.
Thanks a lot, Mark! Today I learned!
To add to this - a perhaps simple change that would be useful in the meantime - on the help for transformers specify which version of the transformer the help relates to, and ideally provide links to the help for older transformer versions - please.
When reviewing workspaces built in an older version of workbench, it would be useful to be able to view the relevant help either through links as above, or by being able to set the help location in FME Tools menu (can change priority, but not location), rather than having to install the specific older version of FME.
johnt
Forum|alt.badge.img+11
  • November 16, 2019
Hi, after looking to find the change to a transformer at different builds, I third this idea to either have a matrix or lookup of some kind. A workspace with only 10 commonly used transformers in it displayed drastically different behaviour between builds 18552 and 18567. Same for reader/writers too. Yes, I accidentally opened the 18567 version in 18552 (forgetting to check all the detail). This has just made me super curious to determine what changed.
Does anything like this exist yet? been looking...
gabriel_hirsch
Forum|alt.badge.img+12
Yes it exist in your installation folder of FME :-)
In the file fmesuite.fmx found at C:\\Program Files\\FME2019.1.3.1\\transformers (or equivalent) I think all transformer history is stored between the tags CHANGE_LOG_START and CHANGE_LOG_END for each version of the transformers. You can open fmesuite.fmx in Notepad and search or build a smart workspace that reads the file and collects all changes and store them elsewhere for further reference.
sleschi
  • March 7, 2022
Thanks for this information. In this file I can find all the old version with there changes.
Because in the workspace there is kind of an error with the now available "Change Log" when you update a transformer. For the GeometryValidator it states, that it is in version 1 or version 3. When I see the Change Log it tells me, it's Version 5 and only show me these changes.
Would be nice, if on the help page for the Transformers, there would be the whole history of the transformers, with all the changes so far.
LizAtSafe
Forum|alt.badge.img+15
  • February 12, 2024
The following idea has been merged into this idea:
jdh
All the votes have been transferred into this idea.
LizAtSafe
  • April 5, 2025
