Gathering Interest
Make the Snapper and AnchoredSnapper Snap in 3D.
Related products:Transformers
  • October 29, 2015
  • 8 replies
  • 130 views
danilo_fme
  • danilo_fme
    danilo_fme
gabriel_hirsch
Make the Snapper snap in 3D.
nielsgerrits
Forum|alt.badge.img+54
@gabriel_hirsch And don't forget the AnchoredSnapper in 3D!
This would be of great benefit to the team that I work in as most of the datasets that we use are in 3D. One of our common tasks is to ensure our 3D lines are snapped but currently the method that we are using is long-winded and cumbersome and involves the following steps:
-breaking the lines down into their vertices
-extracting the XYZ values of the start/end vertices
-comparing the XYZ values of the start/end vertices of lines that are supposed to be joined together
-creating new vertices if the XYZ values differ
-joining the vertices up again to recreate the lines
A 3DSnapper and 3DAnchoredSnapper would allow us to do this in a much simpler and more efficient way.
  • April 5, 2017
This would significantly benefit organisations that use 3D network data especially in the transport and utilities sectors. In particular, large infrastructure projects in the UK, such as Crossrail and High Speed 2, would benefit from having a 3D Snapper and 3D Anchored Snapper.
r5
Forum|alt.badge.img+4
  • November 16, 2018
Snapper and AnchoredSnapper in 3D would be very helpful for the work I do. Also more clarity in the documentation for all spatial transformers as to weather they work in 3D.
Thanks!
It would be great if you could specify if the snapping tolerance should be treated in 2D of 3D.
E.g. (1,1,1) snaps tot (1,2,10) with a 2D snapping tolerance of 1 but not with a 3D snapping tolerance of 1.
A 2D tolerance is especially useful with the 3DAnchoredSnapper.
LizAtSafe
Forum|alt.badge.img+15
  • February 12, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • March 25, 2025
OpenGathering Interest
andreaatsafe
Forum|alt.badge.img+12
Hello! 👋
We’re looking for your input as we begin adding 3D support to the Snapper and AnchoredSnapper transformers!
From initial comments in this thread, we understand that 3D support primarily means including Z values alongside XY when snapping. But we want to make sure we fully understand how you expect this to work in practice.
💬 We’d love to hear from you:
  • What geometry types would you like to snap in 3D? (curves, areas, solids, etc)
  • What coordinate system would your data be using?
  • Are there any specific behaviours you expect 3D snapping to support — or avoid?
If you can share your use cases with a sample workflow or data — either in a comment below or via direct message — that would be incredibly helpful as we shape this project.
Thank you!
