Open
Look in workspace folder for FME components (e.g., CustomTransfomers)
Related products:FME Form
  • February 19, 2025
  • 21 views
virtualcitymatt
Assuming it’s possible, FME Form should look in the same folder as the workspace for FME related components - e.g., CustomFormats, CustomTransfomers.
In FME Flow if you have a CustomTransformer which lives in the same repository as a workspace it will work. It would nice to be able to keep CustomTransfomers in the same location. As it is right now in FME Form if you want to keep all files related to a porject together you need to copy the version from the location where FME can find it (e.g., FME folder) to your project folder.
The process is problematic because you quickly run into issues with copying and keeping track of the version which you’re actually working with in workbench vs what is in your project folder.
JennaKAtSafe
Forum|alt.badge.img+8
NewOpen
JennaKAtSafe
Hi ​@virtualcitymatt, at its core, it sounds like you’re looking for a better way to manage and organize files or assets that are building blocks of your workspace. This is definitely something we can look into. Thanks for sharing your insight!
