Released
ListSorter to support multiple sort-by criteria
Related products:Transformers
  • Jun 8, 2018 12:00 AM UTC
  • 10 replies
  • 157 views
I would like the ListSorter to support multiple sort-by criteria, similar to the regular Sorter. Example:
Currently (FME 2018.0.1) you cannot use multiple ListSorters to accomplish the same thing, since the ListSorter doesn't preserve the existing item order on duplicate sort keys (PR83992).
  • Feb 21, 2019 8:36 AM UTC
Hi David,
Is it a list you have built (e.g. with an Aggregator) ? I have this case, and this is the way I proceed. I have to sort my datas by priority (attribute PRIORITE) then by date (attribute DATE).
I use a Sorter with these two criterias BEFORE the Aggregator so my datas are already sorted after the Aggregator.
Is it what you want to do ? But I have to admit that a mutiple sort-criteria would be great !
Best regard
Patrick
  • Feb 21, 2019 8:51 AM UTC
Sorting the data before list generation isn't always feasible, unfortunately, as the input sort order isn't always guaranteed on the output list. You may also want to sort by an attribute that was introduced by the transformer generating the list, e.g. the NeighborFinder.
tomw202
Forum|alt.badge.img+4
  • Dec 18, 2019 1:51 PM UTC
This would be really useful!
chriswilson
Forum|alt.badge.img+29
  • Jan 7, 2020 10:15 PM UTC
I'd say this is a no-brainer, it would be great to have the option to examine the list in this way without having to explode and then sort on a secondary attribute.
  • Jan 8, 2020 8:56 AM UTC
Hopefully someone with the "power of the purse" at Safe will agree soon as well ;-)
jdh
Forum|alt.badge.img+41
  • Sep 29, 2023 5:34 PM UTC
As far as I can tell, if you chain a set of ListSorters in order of increasing priority you get the correct results.
ie. if you want to sort on attribute A then B you would have two listSorters, the first on B and the 2nd on A.
I haven't tried this with 3 or more, and it would be much nicer if we could have the same functionality as the sorter, where we just add as many criteria as we need.
LizAtSafe
Forum|alt.badge.img+26
  • Apr 6, 2026 10:56 PM UTC
Open→Gathering Interest
LizAtSafe
  • Aug 17, 2026 5:47 PM UTC
Gathering Interest→In Development
LizAtSafe
  • Sep 15, 2026 7:57 PM UTC
In Development→Released
Forum|alt.badge.img+54
  • Sep 16, 2026 9:26 AM UTC
I wonder what the oldest idea to be Released is….
