Archived
list element selection when element number is an attribute value
Related products:Transformers
  • September 14, 2016
  • 67 views
helmoet
Forum|alt.badge.img+8
Hi guys,
It's allmost to simple to imagine that no-one else has thought of this, but when I try to access the elements of a list from an attributecreator, the only possible choices are numbers from 0 to .... for the selection of an individual item of the list. Wouldn't it be a great idea to enable also an attribute reference for a number? So there is an attribute _list_index that I can select as the element sequence number for the element to select? Like the ListIndexer, so one does not have to use that transformer anymore, too.
You can still do it, although it's a bit of a mouthful to type in manually:
my_list{@Value(my_index)}.item
I agree it would be more elegant to be able to select it from the the dialog.
tim_wood
  • May 4, 2018
tim_wood
  • May 4, 2018
Note from Safe: We had to turn off the formatting in this comment due to the community migration. In 2017.1.1.1 the correct syntax needs to be:
@Value(my_list{@Value(my_index)}.item)
tim_wood
  • June 22, 2018
