Released
Linking multiple output ports to an input port straight in UI
Related products:FME Form
  • Feb 25, 2016 12:00 AM UTC
  • 67 views
geolassi
Forum|alt.badge.img+8
Select output ports that you would like to have the link from, click the input port of a transformer or a Writer, and Workbench would create links.
Usually it's too slow to go to View > Feature Type Connections and select the sources and destination, thus I'm linking the ports one by one.
It would be handy to have the functionality of linking multiple output ports to an input port straight in the UI, and not in an separate window (Feature Type Connections).
fmelizard
Forum|alt.badge.img+22
  • Feb 25, 2016 11:53 PM UTC
I like it. It would require us to allow/have multiple output port selection. But once we had that then this is quite reasonable.
  • Feb 26, 2016 6:38 AM UTC
Just want to add that It should also be possible to link single output port to multiple input ports.
