Archived
LineOnLineOverlayer/Intersector overlap count
Related products:Transformers
  • Jan 19, 2016 12:00 AM UTC
  • 26 views
If you send two non-intersecting lines into the LineOnLineOverlayer or the Intersector, the attribute "_overlaps" is set to 1 for both features exiting the Line / Intersected port, even when they do not intersect. The same value of 1 is also set if the two line actually intersect.
I suggest that non-intersecting lines get "_overlaps" set to 0 to make it easier to filter the results accordingly.
Forum|alt.badge.img+54
  • Jan 19, 2016 2:44 PM UTC
The area on area overlayer gives the same result, non-overlapping polygons get given an overlap value of 1, i.e. the polygon overlaps with itself only.
erik_jan
Forum|alt.badge.img+26
  • Jan 19, 2016 3:12 PM UTC
Yes, that is what you would expect.
