When you use a User parameter in a Reader/Writer first time it appears the name $(PARAMETER_NAME), but after you check the OK, if you reopen this Reader/Writer the parameter changes for its value. It would be great if when you come back to this Reader/Writer it still shows the name of the parameter that you are using.
