Archived
JSONFragmentor and JSONExtractor should include _json_error{} on rejected featu
Related products:FME Form
  • September 30, 2019
  • 0 replies
  • 38 views
jdh
Forum|alt.badge.img+41
***Note from Migration:***
Original Title was: JSONFragmentor and JSONExtractor should include _json_error{} on rejected feature
When receiving invalid JSON, the JSONFormatter and JSONFlattener transformers both include _json_error{}.message, _json_error{}.line, _json_error{}.column, _json_error{}.severity attributes in addition to the fme_rejection_code. The JSONFragmenter and JSONExtractor only have the fme_rejection_code, which is often not as useful as one would want.
Additional information is available in the log, but it would be nice if it were available on the feature like the other two JSON transformers.
|WARN  |JSONFragmenter (JSONQueryFactory): Unexpected character: '''. One of the following characters was expected: '"', '}' |INFORM|JSONFragmenter__Rejected_: Feature is: |INFORM|+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ |INFORM|Feature Type: `JSONFragmenter__Rejected__LOGGED' |INFORM|Attribute(string): `fme_feature_type' has value `Creator' |INFORM|Attribute(string): `fme_geometry' has value `fme_undefined' |INFORM|Attribute(string): `fme_rejection_code' has value `NO_RESULT' |INFORM|Attribute(string): `fme_type' has value `fme_no_geom' |INFORM|Coordinate System: `' |INFORM|Geometry Type: IFMENull
VS
|WARN  |JSONFlattener (JSONQueryFactory): Unexpected character: '}'. The following character was expected: 'l' |INFORM|JSONFlattener__Rejected_: Feature is: |INFORM|+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ |INFORM|Feature Type: `JSONFlattener__Rejected__LOGGED' |INFORM|Attribute(encoded: UTF-8): `_json_error{0}.column' has value `419' |INFORM|Attribute(encoded: UTF-8): `_json_error{0}.line' has value `1' |INFORM|Attribute(encoded: UTF-8): `_json_error{0}.message' has value `Unexpected character: '}'. The following character was expected: 'l'' |INFORM|Attribute(encoded: UTF-8): `_json_error{0}.severity' has value `invalid value' |INFORM|Attribute(string)        : `fme_feature_type' has value `Creator' |INFORM|Attribute(string)        : `fme_geometry' has value `fme_undefined' |INFORM|Attribute(string)        : `fme_rejection_code' has value `NO_RESULT' |INFORM|Attribute(string)        : `fme_type' has value `fme_no_geom'
