Archived
JSONFragmenter should use JSON Document input parameter
Related products:Transformers
  • Aug 22, 2017 12:00 AM UTC
  • 0 replies
  • 45 views
jdh
Forum|alt.badge.img+41
All the JSON transformers except the JSONFragmenter allow the input JSON to be an attribute, free text, or a parameter containing the json, usually called JSON Document.
The JSONFragmenter requires an attribute containing the text or a parameter containing the name of that attribute, which is inconsistent with the behaviour of the other transformers
