Released
Joiner - have an option to see data that has not been successfully joined.
Related products:FME Form
  • Jan 18, 2016 12:00 AM UTC
  • 50 views
andybarnesosgb
With the Joiner transformer there is not option to see the data that has not joined to something successfully. It would be nice to see which features that have been unsuccessful, so perhaps a rejected or unsuccessful or not joined port out of the transformer. Currently the only way of seeing whether features have not joined is buy looking at the feature counts either side of the joiner. Even then you do not know which one did not join.
  • Jan 18, 2016 3:36 PM UTC
Hi
Could you not test for _matched_records = 0 after the Joiner? From the help:
The _matched_records attribute specifies how many records in the database the feature matched to.
David
erik_jan
Forum|alt.badge.img+26
  • Jan 18, 2016 5:36 PM UTC
As David suggested the _matched_records = 0 test is what you need. But to do that you must choose a cardinality that allows 0 matches to pass. You can choose from these options:
