Archived
Joiner: Better logging
Related products:Transformers
  • May 16, 2017
  • 19 views
sigtill
Forum|alt.badge.img+25
When Joiners fail they output the following in the logfile:
2017-05-16 10:42:17|  53.6|  0.0|ERROR |BADNEWS: 0 matches were found in the table used by relation `Joiner_4' (which is supposed to be 1-1) -- key values were:  X== `'  (relation.cpp:694) 2017-05-16 10:42:17|  53.6|  0.0|ERROR |0 matches were found in the table used by relation `Joiner_4' (which is supposed to be 1-1) -- key values were: XXX== `'  2017-05-16 10:42:17|  53.6|  0.0|ERROR |(featproci.cpp:701) - (cmrelate.cpp:227) - (relation.cpp:694) 2017-05-16 10:42:17|  53.6|  0.0|ERROR |BADNEWS: A fatal error has occurred. Check the logfile above for details (dynafact.cpp:315)
Also write the complete feature that failed in the logfile (similar to putting it through a Logger) for instance:
2017-05-16 10:42:17|  53.4|  0.0|INFORM|=========================================================================== 2017-05-16 10:42:17|  53.4|  0.0|INFORM|Joiner_4 - Logg failed feature: 2017-05-16 10:42:17|  53.4|  0.0|INFORM|+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 2017-05-16 10:42:17|  53.4|  0.0|INFORM|Feature Type: `Joiner_4_Logger' 2017-05-16 10:42:17|  53.4|  0.0|INFORM|Attribute(32 bit integer)         : `x' has value `1' 2017-05-16 10:42:17|  53.4|  0.0|INFORM|Attribute(string)                 : `y' has value `fads.fds.fsad.fdsafdsa' 2017-05-16 10:42:17|  53.4|  0.0|INFORM|Attribute(32 bit integer)         : `z' has value `fasfasd' 2017-05-16 10:42:17|  53.4|  0.0|INFORM|Attribute(32 bit integer)         : `asdf' has value `ffasdfsda' 2017-05-16 10:42:17|  53.4|  0.0|INFORM|Attribute(string)                 : `134' has value `234234' 2017-05-16 10:42:17|  53.4|  0.0|INFORM|Attribute(string)                 : `fasdf' has value `32434'
  • May 16, 2017
Are you sure you haven't accidentally activated debug logging? Those BADNEWS messages seem to indicate it.
