Released
Job Queues - Order of Engine Assignment
Related products:FME Flow
  • Jul 16, 2021 2:45 PM UTC
  • 61 views
dbaldacchino1
Forum|alt.badge.img+14
We should be able to set up the order of engine assignment. For example I would like to set up a job queue for high priority workspaces where I assign our Static Engines first and then assign a few dynamic engines. That way if the Static Engines are idle, they can process the jobs and if they are busy, Dynamic Engines can take over the task. Currently the picking order in the job queue is not respected and seems to be Alphabetical so Dynamic Engines are picked first.
LizAtSafe
Forum|alt.badge.img+26
  • Jun 15, 2024 2:57 AM UTC
https://docs.safe.com/fme/html/FME-Flow/WebUI/Queue-Control.htm
