Archived
InspectLogger - works both on FME Desktop and Server
Related products:Transformers
  • January 24, 2018
  • 15 views
sigtill
Forum|alt.badge.img+25
Create a hybrid called InspectLogger which works like an Inspector when in FME Desktop - and as a logger on FME Server. Has the parameters of both Inspector and Logger
  • January 24, 2018
Hm, I'm thinking this should be fairly easy to do with a custom transformer. You could determine if your workspace is running on FME Desktop or Server by e.g. checking if $(FME_JOB_ID) has a value and then route to either a Logger or an Inspector.
