Released
InlineQuerier and SQLExecutor text editor behavior changed in 2016, revert to 20
Related products:FME Form
  • Aug 24, 2016 12:00 AM UTC
  • 32 views
***Note from Migration:***
Original Title was: InlineQuerier and SQLExecutor text editor behavior changed in 2016, revert to 2015
The text editing of SQL in the InlineQuerier and SQLExecutor used to allow for simple drag-and-drop of the field names into the notepad space,
now in FME2016 dragging a field name creates double quotes and a line feed character, all of which have to be deleted
please can the drag-and-drop behaviour return to just the field name
- or ideally with the addition of its table prefixed e.g table_name.field_name
@j I believe the quotes are added so that if you're working with a case sensitive database like PostGreSQL or Oracle your queries will still work. But the linefeed is irritating and I've logged a change request and will post here when this is addressed - PR71876
Update on Newlines:This was a bug introduced in FME 2016.1 and should already be fixed in the latest FME 2017 betas.
This has been released as part of FME 2017.0 . Visit http://www.safe.com/downloads to download it and give it a spin.
