Open
Increase log limit in SQLExecutor
Related products:Transformers
  • Feb 24, 2017 12:00 AM UTC
  • 34 views
Nowadays, FME log does not show all the information when SQLExecutor transformer is used in order to execute Oracle procedures.
For example, If several procedures calls are used in the SQLExecutor, only the first three procedures calls are showed in the log. The others no. So you don´t know how the process is be going.
tris_w
Forum|alt.badge.img+8
  • Oct 16, 2018 4:35 PM UTC
We have the same problem, often with a dozen or so SQL statements & procedure calls in an SQL Executor. There isn't any real logging in the FME log as it just says " Logging limit reached for the preceding message. Further instances of this message will not be logged". Would be great if we could control this, or at least have the ability to see logging from all SQL statements run.
