Archived
Improvments center line replacer
Related products:Transformers
  • Feb 27, 2019 12:00 AM UTC
  • 24 views
checcosisani
Forum|alt.badge.img+14
Hy
attached the dataset that I used to test center line replacer
checcosisani
  • Mar 2, 2019 9:00 PM UTC
Hi Mark
I received this form Dan
hmm my dataset is 28 mb How can send ?
DanAtSafe checcosisani · 3 days ago
Hi @checcosisani That looks bad :( I assume you're displaying the coordinates on the lines? We're still making refinements to this approximate mode. Can you send us your source data via https://www.safe.com/support/report-a-problem/ ? Thanks!
fmelizard
Forum|alt.badge.img+22
  • Mar 4, 2019 3:26 AM UTC
Hi @checcosisani If you complete the form to make a case at that link, you should be able to upload the file there. Or else FTP it to ftp://ftp.safe.com/incoming and then mention the file name in the case. Thanks!
