Released
Improvements to the DateTimeConverter
Related products:Transformers
  • September 13, 2018
  • 84 views
Forum|alt.badge.img+54
The old date time formatter allowed setting the attribute to a default value if it could not be converted. This was useful as it allowed you to set to a null value or dummy date. The datetimeformatter just passes all features with invalid dates out the rejected port, if formatting a number of attributes with dates there is no information as to which attribute has the invalid date.
Rejected features also seem to loose the original data - it would be helpful to retain these so that further work/ manipulation on the data could be done.
LizAtSafe
Forum|alt.badge.img+25
Open→Released
LizAtSafe
In FME 2023 and newer using the latest version of the DateTimeConvertor should address a few of these: the rejection message should now indicate what attribute could not be converted and the original attribute values are maintained
