Archived
Improvement of createDB/dropDB of FME Server database
Related products:FME Flow
  • Oct 26, 2017 12:00 AM UTC
  • 26 views
revesz
Forum|alt.badge.img+22
The side effect of having FME database on a separate server is that it must be rebuilt at every upgrade. The provided drop/createUser/DB/Schema is not bad but the process of the FME database rebuild could make life easier with a couple of improvements (which are possible in all SQL Server/Postgresql/Oracle):
  • In addition to dropDB/dropUser an emptyDB which drops all the database objects in the createDB/Schema script but not the database itself would save the user management and would require less privileges.
  • Using variables in the createDB script eg. create the db or not, starting value of job_id, etc
LizAtSafe
Forum|alt.badge.img+26
  • Apr 5, 2025 4:13 AM UTC
Open→Archived
