New
Improve the UX on the Web Service/Web connection workflow
Related products:FME Form
  • April 18, 2026
  • 81 views
salvaleonrp
Forum|alt.badge.img+23
The web connection/webservice features have been around for a few years and it needs some improvement in the UX, especially to help new users. Here’s a few suggestions:
1. once a web service is created by a user, services, templates and connections are all mixed up in the drop downs or that long list of templates and web services. Some type of separation or categories between user created services from web services templates either on the long list in FME options or the drop downs in the connectors.
2. The Add Web Connection drop down from the transformers is confusing to new users, when the web connection is not a simple token or key or the web service is not created yet.
3. On the MCP Caller (Beta) web connection from FME Options, I have to type the MCP URL and API key three times before I can use it. Once the URL is configured from the template ans applied. Once applied, the URL should persist in the drop down when I Test the web service and create with Add my Web Connection.
andreaatsafe
Forum|alt.badge.img+17
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
mgg_beca
Forum|alt.badge.img+20
  • July 29, 2026
I 100% support this idea.  I have begun prefixing all user created web services with a period “.” to bring them to the top of the list.  It seems like the list could automatically be separated into user created and template or ootb services.
I would also suggest that the default services should not be editable - they should all effectively be templates.  Then users will always right click create from these and won’t run the risk of breaking a default template.
