Released
improve SQLExecutor to operate the same way on all databases it supports
Related products:FME Form
  • August 11, 2017
  • 85 views
It would be good if the SQL Executor operates the same way on any database formats its supports.
Recently I've had an issue whereby I cannot execute a 'DELETE from <my-table>' statement on SpatiaLite, but I can execute the same statement on Oracle Spatial.
See the following Knowledge Centre question and supporting answers/comments at
https://knowledge.safe.com/questions/50230/sql-executor-and-spatialite-delete-or-drop-command.html
I have a feeling this is also the cause why "with" statements don't work either.
chau
Forum|alt.badge.img+8
  • January 9, 2018
I think my issues with creating views (and indices, though they can be made using the SQLite non-spatial) are due to the same limitations.
kimo
Forum|alt.badge.img+10
  • September 10, 2018
At least add a note in the documentation! ie We only support read-only SQL Executor queries.
But why? I am using spatialite precisely to do fast sql selections for real-time updates. I really need a Truncate function. Drop and Create is not possible because it invokes a file lock.
andreaatsafe
Forum|alt.badge.img+17
I'm please to let you know that a recent update to FME 2020.2 beta (build 20709 and newer) has enabled SQL executing statements for the SpatiaLite format in the SQLCreator and SQLExecutor. We now support more than read-only SQL statements when using the SpatiaLite format (eg. INSERT/UPDATE/DELETE/CREATE/DROP).
You can find the latest beta build here: www.safe.com/beta
- Andrea
