Archived
Improve SQL inputs on readers
Related products:Integrations
roland.martin
Forum|alt.badge.img+11
The WHERE and SELECT statements - I would very much like:
  1. To see some code colouring on the SQL view - it seems to just change it to fixed-width text
  2. To be able to input line breaks so that I can understand the query next time I open it
  3. To be able to import (and export) saved *.sql files
  4. To be able to test the statement
  5. If SELECT is blank, I'd like it to automatically populate itself by building the query that FME is using, i.e. "SELECT * FROM [table] WHERE [where_clause]"
  6. It would be amazeballs if you could import the schema from the query and overwrite the attribute names in the reader properties
roland.martin
fmelizard
Forum|alt.badge.img+22
Very good suggestions. We have an idea to one day merge the FeatureReader with the SQLCreator and these are very good suggestions for that day...if not before.
bruceharold
Forum|alt.badge.img+19
For database formats, how about a statement builder?
chad
  • May 20, 2018
Is that day coming soon?
