Archived
Improve recognition for ESRI File GDB format in reader
Related products:FME Form
  • Aug 17, 2017 12:00 AM UTC
  • 66 views
embeezy
Forum|alt.badge.img+7
Quite commonly I read in a zipped fGDB and would like to suggest that the auto-recognition of this format be improved.
FME (2017.1) recognises a zipped fGDB as being of format "EDIGéO". fGDB is surely a much more common format and defaulting to "Esri Geodatabase (File Geodb)" would probably help many of us.
  • Aug 17, 2017 12:46 PM UTC
For Safers reading this: you'll want to be looking for PR56665.
  • Aug 17, 2017 4:38 PM UTC
Additionally - can it check if a folder is actually a GDB and not just a folder with .GDB in the folder name - maybe tricky?
Often get a zip file which when you unzip can become
.\\MyExample.GDB\\MyExample.GDB (with the latter actually being the database. You can't progress through the first folder when browsing as it thinks it is a GDB.
