Archived
Improve handling of null geometries by FeatureReader with SpatialFilter
Related products:Transformers
  • Jul 27, 2017 12:00 AM UTC
  • 76 views
Forum|alt.badge.img+54
Currently if initiating features are sent to a FeatureReader with a null geometry and the spatial filter is set to Envelope Intersects the feature reader returns every single record in the table. Initiators with null geometries should be output via the rejected port where the FeatureReader is using a spatialfilter
  • Jul 27, 2017 10:51 AM UTC
I'd be tempted to call that a bug. Did you contact support about it?
  • Jul 27, 2017 11:12 AM UTC
Can you recreate in 2017?
  • Jul 27, 2017 6:36 PM UTC
Recreated in 2017 - easy to see why with following...
From log with Null geometry:
ORACLE Reader: Executing SQL Statement `SELECT "COUNTY"."GID", "COUNTY"."NAME", "COUNTY"."GEOM" FROM "COUNTY"' to obtain features for feature type `COUNTY'
From log with Box geometry:
ORACLE Reader: Executing SQL Statement `SELECT "COUNTY"."GID", "COUNTY"."NAME", "COUNTY"."GEOM" FROM ( SELECT * FROM "COUNTY" A WHERE (MDSYS.SDO_RELATE( A.GEOM, mdsys.sdo_geometry(2003,29902,null,mdsys.sdo_elem_info_array(1,1003,3),mdsys.sdo_ordinate_array(280000,410000,400000,440000)),'mask=ANYINTERACT querytype=WINDOW') = 'TRUE') ) "COUNTY" WHERE 1 = 1' to obtain features for feature type `COUNTY'
fmelizard
Forum|alt.badge.img+22
  • Jul 31, 2017 3:50 PM UTC
PR 78826 has been filed to address this. Once the fix has been implemented, we'll update the idea here. We appreciate your involvement in helping us make FME even better!
