Open
Import/Export deployment parameters to FME Flow
Related products:FME Flow
robd
I have multiple FME Flow instances, it’d be helpful to be able to import/export deployment parameters from/to the deployment parameter store on FME Flow. At the moment I can create via Form and Create/Remove via web interface. A nice import/Export button here with the option to overwrite would be great:
Thanks!
rylanatsafe
Forum|alt.badge.img+14
Thanks for submitting this idea, ​@robd ! Have you tried using Flow Projects to migrate deployment parameters? Curious if that meets your needs or where it falls short—understanding that would help us evaluate improvements here.
rylanatsafe
New→Open
