Archived
Implement Pole of Inaccessebility from mapbox
Related products:Integrations
  • June 22, 2017
  • 20 views
esietinga
Forum|alt.badge.img+7
Implement mapboxes Pole of Inaccessibility algorithm to quickly find visual center of complex polygons. Source available from:
https://github.com/mapbox/polylabel
fmelizard
Forum|alt.badge.img+22
Hi @esietinga
As a work around (it's quite slow at the moment) you can use the LargestInnerCircleCreator, and then use the CentrePointReplacer to get the Pole of Inaccessibility. It's only an approximation but it should do the trick
