Archived
I'd like FME to support writing data to Excel Tables (Issue # FMEENGINE-37822)
Related products:Integrations
  • October 29, 2018
  • 122 views
I just follow this tutorial (https://knowledge.safe.com/articles/34364/using-a-template-file-when-writing-excel-data.html) try to write data to Excel table and found looks difficult, see attached image, write to Named Range in Excel looks perfect. Thank you.
brianatsafe
Forum|alt.badge.img+13
A bit more information about Excel Tables:
A table is a special structure in an Excel document. It has filter cells on the headings and special formatting for the cells. In excel, you can specify a table and then as you add data to it, the formatting expands to each column or row added. See here for an example: http://www.excel-easy.com/data-analysis/tables.html
You can create a template excel file with a table but you have explicitly know the Rows/Columns that you need or the formatting will not be applied to all the data.
gogopotter90
Forum|alt.badge.img+14
But if we do not know ,how many rows or columns will be in the output bcs it depends on the input file,may be the input changes.so i think,we should do sth.relates to count rows and column to generate Excel Table output as we required
LizAtSafe
Forum|alt.badge.img+25
Updated idea statusGathering Interest→Archived
Idea merged into:
All the votes from this idea have been transferred.
LizAtSafe
Idea merged into:
