Released
HTMLReportGenerator - add HTML
Related products:FME Form
  • May 20, 2016 12:00 AM UTC
  • 5 replies
  • 76 views
sigtill
Forum|alt.badge.img+25
It would be great to add a Page Content called HTML where the user could just input any HTML at that place.
mathieu_ambrosy
Forum|alt.badge.img+5
A client just asked me for the same thing :
He wants to add html code in the "label attribute" to obtain an OSM Leaflet with html code in the information box when he clicks on the entity on the map.
  • Jun 13, 2016 4:19 PM UTC
Hello,
i've got the same prolbem.
I've done this FMW :
I prepare my html content and after the htmlreportgenerator, i made a personalized transformer to replace & lt; and & gt; by <and>.I'm not sure that it will work in all the case but it work fine with my example.You can see the result on this web site : http://www.cap-atlantique.fr/node/679.
xlsxr2html-loop-test.zip
Forum|alt.badge.img+4
I did the same thing too and replaced the encodings for less than and greater than tag opening and closings with < and > using the string replacer after the html report generator and before the html writer.
  • Sep 10, 2016 5:04 AM UTC
Currently the transformer converts every special character that is used to define html tags to its entity reference. Therefore, for example, you cannot embed a <a> element (i.e. link) to either a table cell or a paragraph (Header content). It would be better if an option would be added so that html tags within the source string can be written as-is into the resulting html document.
rylanatsafe
Forum|alt.badge.img+14
This feature has been released and is available in FME 2017.0 and Newer. Please give it a try!
@sigtill @xav_cap @mathieu_ambrosy @james_rutter
