Open
Have Workspace run start date/time an FME Parameter
Related products:FME Form
  • May 21, 2018 12:00 AM UTC
  • 37 views
One very frequent issue that I've come across is the need to record the timestamp during a model. Currently, the main way to do this without having different timestamps across a dataset is to capture the timestamp at the beginning of the model and then to store it in a parameter.
It would be great if instead, I could use a built in parameter, such as FME_RUN_DATETIME.
This parameter would capture the datetime when a model is run for use in later calculations, attribution, custom logs, and fanouts as needed without having to add multiple transformers to each model.
  • Oct 3, 2018 12:12 PM UTC
I have de same suggestion. I use Python code into a Private Parameter to this. But it would be easier with a native FME option.
Python code is :
from datetime import datetime
time = datetime.now()
return time.date()
