Archived
Get Google Analytics data
Related products:Integrations
  • Oct 13, 2016 12:00 AM UTC
  • 5 replies
  • 73 views
How about the possibility to import Google Analytics data? Now I cannot have Web Connection to Google analytics, like Google adSense or Google Gmali do.
In HTTPCaller transformer you can use Oauth2 authentication for several Web services, like Google AdSense and Google Gmail. Is it possible to add Google Analytics in the list of Web Services to create Named Web Connections?
Google Analytics provides geographical data suitable to transform.
  • Jan 2, 2017 3:33 AM UTC
Google Analytics holds an important piece of data that I would like to leverage with FME
  • Apr 2, 2018 7:15 PM UTC
Jordi,
I have added a Google Analytics Connector to the FME Hub.
https://hub.safe.com/web_connections/google-analytics
I hope it helps! Let me know if you have any questions.
John
Hi John,
Thank you for posting your connector. I'm hoping you could post a sample HTTPCaller. I've had good success getting the token using your Web Connector, but am having difficulty getting the HTTPCaller configured properly. I'm sure it's all in the directions you've supplied, but getting the options set properly is escaping me.
Cheers,
Greg
asadamjad
Participant
Forum|alt.badge.img+12
  • Participant
  • Aug 5, 2022 5:02 PM UTC
how can i connect this ???
