Archived
Get FME Version ++ as parameters
Related products:FME Form
  • Oct 17, 2019 12:00 AM UTC
  • 77 views
sigtill
Forum|alt.badge.img+25
I want to get the following data
FME 2020.0.0.0 Beta (20190920 - Build 20090 - WIN64)
FME Desktop Professional Edition (floating)
As Parameters within a workspace to be able to write which version of FME converted the file. Is this possible both on Desktop and Server?
For instance:
FME_VERSION
FME_BUILD
FME_BIT
FME_PLATFORM
nielsgerrits
Forum|alt.badge.img+67
Some parts are parameters already:
$(FME_OS)
Windows
$(FME_PRODUCT_NAME)
FME(R) 2019.1.2.0
$(FME_BUILD_DATE)
20190829
$(FME_BUILD_NUM)
19630
When I needed the version and last saved date I read the running workspace and parsed it. But info about the software and platform running the workspace can't be gathered this way.
  • Oct 17, 2019 9:21 AM UTC
You can already access the following "hidden" parameters using either Python or the ParameterFetcher:
  • FME_BUILD_NUM (e.g. "19642")
  • FME_BUILD_DATE (e.g. "20191007")
  • FME_OS (e.g. "Windows")
  • FME_PRODUCT_NAME (e.g. "FME(R) 2019.1.3.0")
There doesn't seem to be a super obvious way of getting the "bitness" of FME, but you can use the following Python code somewhere within FME, which will return either 32 or 64 depending on the bitness of FME:
import struct bitness = struct.calcsize("P") * 8
You can get the FME edition and license type in Python like this:
import fmeobjects product = fmeobjects.FMESession().getAllProperties()['PRODUCT NAME'])
Example: "FME Desktop Oracle Edition (floating)".
If you look further into the FME session properties you can even find out which formats are currently licensed, e.g. how to check if your current FME license allows you to write to SDE:
can_write_to_sde = fmeobjects.FMESession().getAllProperties()['SDE WRITER'] == 'LICENSED'
All of this should work on both Desktop and Server.
jelle
Forum|alt.badge.img+23
  • Oct 23, 2019 2:40 PM UTC
I would primarily be interested in the 'FME_Platform' Parameter for creating different actions on FME Server / FME Cloud
