Open
Get EPSG code by CoordinateSystemExtractor
Related products:Transformers
  • July 24, 2019
  • 206 views
harmen_kampinga
With the CoordinateSystemExtractor, only a description of the coordinatesystem is given. It would be great to have the EPSG code as well.
For example:
_coordsys : _Netherlands-RDNew-2008_0
_epsg: 28992
So I can use the 28992 code to extract more details from this coordinatesystem by building this URL, for example: https://epsg.io/28992.gml
  • July 24, 2019
It would be convenient in some scenarios.
As a workaround in the interim, you can use the CoordinateSystemDescriptionConverter to convert FME coordinate system name to corresponding EPSG code.
harmen_kampinga
Yes, that's a workaround ;-)
As most of FME: there are a "thousand roads leading to Rome" and that's why it's so beautiful!
harmen_kampinga
If you like it, @takashi : would you please have a thumbs up for this idea? Thank you
