Open
Geometry Picker window size
Related products:FME Flow
  • Oct 13, 2020 8:13 PM UTC
  • 90 views
itay
Forum|alt.badge.img+19
Wouldn't it be great to have a parameter to define the initial window size of the geometry picker parameter?
Yes you can adjust the size of the window once it is open, but it would be great to be able to define it yourself.
Cheers,
Itay
gschleusner
  • Jan 28, 2021 8:36 PM UTC
Really want this as well. I can only stretch horizontally. I can't actually make the frame larger overall.
dbaldacchino1
Forum|alt.badge.img+14
Completely agree @itay. I also think that the map starting position and zoom factor should be customizable on FME server and not just based on the Configuration settings of the Geometry parameter in Workbench. It would be nice if these, plus window default size settings were able to be set in an FME Server App as well.
thijsknapen
Forum|alt.badge.img+12
  • Feb 20, 2021 3:38 PM UTC
I'm actually unable to change the size of the 'Geometry Picker' sub window in my browser. I think the default size is pretty small, and I just wanted to post an idea on this as well. I tried this using firefox, edge and internet explorer.
@itay, can you maybe elaborate on how you managed to change the size of the geometry picker window? Is it just a matter of a different browser (e.g. Chrome or Opera), or is there some other kind of trick involved?
LizAtSafe
Forum|alt.badge.img+26
  • Feb 8, 2024 10:35 PM UTC
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
