Open
Generate Log File Folder
Related products:FME Form
  • Sep 14, 2016 12:00 AM UTC
  • 99 views
hkingsbury
Forum|alt.badge.img+73
I was running a workbench from G: and wanted to view my logs. So I set my writers to output a log file for G:Logs but it didn't want to do it. When I created the folder 'Logs' it worked fine.
In future releases it would be great to have FME automatically generate the neccessary folder(s) to place a log file in
todd_davis
Forum|alt.badge.img+23
  • Sep 15, 2016 9:02 AM UTC
Agree, when you go to the effort of setting a non-default log location, then it would be great if fme would create the folder if it doesn't exist, otherwise if you move the workbench and the log folder was relative, the process falls over if the folder doesn't already exist.
tim_wood
Forum|alt.badge.img+8
  • Oct 22, 2019 9:13 AM UTC
Thanks to 1Spatial who pointed me to this when I had the same problem. Mine was happening via a WorkspaceRunner using a path for the log file generated from attributes.
I expected FME to just go ahead and create the folder because it does that with Writers.
jdh
Forum|alt.badge.img+41
  • Oct 22, 2019 5:29 PM UTC
My current workaround is to set the log to a scripted parameter, which checks to see if the directory exists and if not, it creates it.
