Open
for feature type table handling - Truncate if exists - create if needed
Related products:Integrations
  • Mar 29, 2018 12:00 AM UTC
  • 156 views
mikem
for an output table (in my case esri sde) could you add the option to "Truncate - Create if Needed" i seem to come across this need somewhat often
lucky
  • Jul 20, 2018 8:46 AM UTC
This is really necessary!
Older Versions of FME automatically created a FeatureClass (Table), if it didn't exist!
So I could handle with "Truncate first" in older Version!
With the new Table Handling I must know if a table exists or not:
when I use "Truncate Existing" - FME does not create the table if it does not exist!
when I use "Create if Needed" - FME does not truncate it!
when I use "Drop and create" - FME-Writer stops with an error if it exists and someone is connected to the table.
So you are right: "Truncate and create if Needed" could solve this Problem!
ranga_tolapi
Forum|alt.badge.img+11
  • Sep 17, 2020 10:58 AM UTC
"Truncate Existing or Create If Needed" is very much required.
oscard
Forum|alt.badge.img+23
  • Jan 18, 2021 9:31 AM UTC
The "Truncate Existing or Create if Needed" would save me a lot of headaches
