+1, I could've used that just yesterday. In stead I had to login through a VPN + Citrix + RDP just to have a quick look in Explorer. It would be particularly useful for File Geodatabase folders where you usually end up with a lot of files.
Are you talking about seeing the size of folders that you uploaded to the Resources section of FME Server? Or seeing the size of the File Geodatabase folders in the FME Server repository if you just uploaded it with the workspace (which you can't see at all right now)?
Commonly data that was uploaded with workspaces took up a lot of space on FME Cloud, especially because you couldn't see the data that had been uploaded (or the size).
In FME 2020.1 if you go into the workspace folder you can see how many files have been uploaded to that workspace and the size of them. If you click on 'View Files' you can see each individual file and it's size and remove it if you want to.
Under Resources > Data > <yourFolder> you can also see the size of data and you can delete files.
There's still work to be done to make it easier to find to find the big folders, but this is a step in the right direction.
