Archived
fmeobjects support for complex lists
  • Dec 23, 2015 12:00 AM UTC
  • 65 views
It would be helpful if the fmeobjects API had better support for complex lists. Consider the list:
_list{0}.id = '502' _list{0}.text = 'abc' _list{1}.id = '36' _list{1}.text = 'xyz'
The following fmeobjects method currently returns None:
items = feature.getAttribute('_list{}')
To access child elements, you currently have to access them invidudually and then assemble them into an appropriate structure yourself.
It would be very handy if the getAttribute() method could return a nested Python dictionary containing the entire list with its elements, e.g. using the sample list above:
items = {0: {'id': '502', 'text': 'abc'}, 1: {'id': '36', 'text': 'xyz'}}
This would get rid of a lot of boilerplate code in Python scripts dealing with FME lists, as we could access individual list items using syntax like:
>>> print items[1]['text'] 'xyz'
  • Dec 23, 2015 9:42 AM UTC
That's a nice idea. It might also be good that the return value is a list containing dictionaries as its elements, similar to a JSON array. e.g.
>>> print items [{'id': '502', 'text': 'abc'}, {'id': '36', 'text': 'xyz'}] >>> print items[0]['id'] 502
  • Dec 23, 2015 10:34 AM UTC
Agree. That would of course also be perfectly fine.
  • Jun 14, 2016 9:20 AM UTC
dbaldacchino1
Forum|alt.badge.img+14
I'm just starting to use some python for complex list handling and am finding it's not possible to write attributes with nested lists. So I think this wish is related to what I'm butting my head against (ex: setting attribute to [['A1', 'A2'],['B1','B2'],....])
