Released
FME Workspace reader should return connection and bookmark info
Related products:FME Form
  • December 7, 2015
  • 11 replies
  • 103 views
The FMW reader reader need to return more information for it to be truly useful, notably
  • Transformer connections
  • Bookmarks (which transformer is in which bookmark)
  • December 5, 2016
Use cases include automating workspace documentation, see also https://www.linkedin.com/pulse/automated-workspace-documentation-patrick-koning
denniswilhelm
Forum|alt.badge.img+21
  • December 6, 2016
In addition to that more detailed information about database connections would be helpful. Especially the actual database (NamedConnection, Connection File (e.g. SDE) or the instance with url and port) are relevant when documenting workspaces.
fmelizard
Forum|alt.badge.img+22
  • February 10, 2017
As of FME 2017 Connections are read from an FME Workspace using the FME Workspace Reader. Bookmarks are being read but we can't yet read what is inside the book mark. Thanks for the suggestions. [Note: this comment was edited]
fmelizard
  • February 10, 2017
@denniswilhelm1 this was a good suggestion but was not covered in the recent work we did here. Do you mind creating a new idea for this suggestion
  • February 10, 2017
Connections are already a great addition, thanks!
fmelizard
  • February 10, 2017
You were awarded the Inventor Badger for this. Suggesting an Idea that has made it into the product.
  • February 10, 2017
Thanks, I've always wanted a badger! :-)
patrick_koning
Forum|alt.badge.img+7
Hi @david_r
I incuded a small workspace in releasecandidate 2017 that strips a .fmw file to a xml and then reads out the bookmarks or annything as you wish as it is xml.
A workaroud for the timebeing.
For each feature there are local coordinates wich can be used to build relations.
Greetings,
Patrick Koning
fmw-to-xml.fmw
patrick_koning
Hi @david_r
Greetings,
Patrick Koning (126.2 kB)
  • February 23, 2017
Nice, thanks a lot!
This has been released as part of FME 2017.0 . Visit http://www.safe.com/downloads to download it and give it a spin.
