Released
FME Server WebUI: Schedules - Start once
Related products:FME Flow
  • December 9, 2016
  • 82 views
After scheduling a FME-Server job I want to try it out if everything runs as expectet. If I run it with "Immediately" checked, my previously set date and time settings are overwritten with the time at the given moment I run the scheduled task.
An option to run the scheduled job once on demand without affecting any settings would therefore be nice. Similar to the windows task scheduler option to just run a task on demand.
revesz
Forum|alt.badge.img+22
  • December 9, 2016
An on demand run is also useful when a job fails and I want to run again without affecting the schedule or copy/paste all the parameters.
Also, when the engines run under a set user privilege, testing with a different (my) privilege can lead to different result in success/fail, on demand run of the schedule would make testing/debugging much easier.
  • January 18, 2017
Windows Task Scheduler provides a dialog where you can see your tasks and run one or more of them. For the web it would be great to have a dialog with checkboxes beside each schedule so that you could run any number of them without having to actually go into the schedule, wait for it to load, scroll down and then run the schedule.
rylanatsafe
Forum|alt.badge.img+14
  • March 12, 2019
Thank you very much for contributing your idea to the FME Community! Please note that this idea has been marked as a Duplicate of an existing idea: Run Now button on FME Server Scheduling page – and also note that idea is currently implemented in the latest FME Server 2019.0 betas! Please let us know if you do not feel the description of the idea (referenced below) matches your request. https://knowledge.safe.com/idea/53136/run-now-button-on-fme-server-scheduling-page.html https://www.safe.com/support/support-resources/fme-downloads/beta/
LizAtSafe
Forum|alt.badge.img+25
  • June 15, 2024
https://docs.safe.com/fme/html/FME-Flow/WebUI/Automations-Triggers/Trigger-Schedule.htm#TestingaScheduleInitiatedWorfklow
