Released
FME Server to support MS SQL 2016 as the FME Server Database
Related products:FME Form
fmelizard
Forum|alt.badge.img+22
  • April 25, 2017
We are seeing clients adopt 2016, particularly the "Always On" capability and their preference is to support the FME Repository here to support Active-Passive configuration with high-availability / redundancy on the database component. JDBC 6.0 for MS SQL Server is the currently supported spec from Microsoft.
nic_ran
Forum|alt.badge.img+20
  • April 28, 2017
While you're in there.... I would add my request to allow for dynamic port allocation to be used as well:
https://knowledge.safe.com/idea/43500/fme-server-configuration-using-sql-server-dynamic.html
rylanatsafe
Forum|alt.badge.img+14
FME Server has been tested with Microsoft SQL Server 2016.
If there are any features not yet supported that you would like to see, please create a new idea in the FME Community. If any issues are discovered, please report them to our Support Team.
