Archived
FME Server System Event when Engine start fails
Related products:FME Flow
  • July 13, 2022
  • 32 views
geobroetchen
Forum|alt.badge.img+19
FME Server should have a system event which triggers when a FME Engine can't be started.
For example two FME Engines are licensed and also configured to be used but only one FME Engine is started and the other one is down for more than 10 minutes.
So the administrator can be notified and investigate the reason.
LizAtSafe
Forum|alt.badge.img+25
Open→Archived
