Open
FME Server apps to return Errors
Related products:FME Flow
  • Sep 4, 2020 12:42 PM UTC
  • 11 replies
  • 459 views
itsmatt
Forum|alt.badge.img+48
When using a FME Server App which fails for some reason there is no built in way to return an error message to the user. It is always an unknown problem.
It would be great if there was a way to return a few more details to the user. This is particularly important when an invalid dataset is uploaded.
Without a workaround there is currently no way to let the user know their data needs to be fixed.
warrendev
Forum|alt.badge.img+28
  • Sep 4, 2020 5:17 PM UTC
This would be really helpful!
  • Sep 24, 2020 5:17 PM UTC
great idea !
anderstgd
Forum|alt.badge.img+9
  • Mar 19, 2021 10:14 AM UTC
Thank you for adding this idea! This is exactly what I was going to suggest.
reedwhit
Forum|alt.badge.img+15
  • Apr 16, 2021 1:59 AM UTC
could you email the log or message the user? when they run a long job.... or have an option to stream the Fatal parts of the log to the browser after the app runs.
thijsknapen
Forum|alt.badge.img+12
  • Jul 15, 2021 7:23 PM UTC
Hi @virtualcitymatt,
I struggled with the same thing. My preferred method would be to use a terminator message with a custom termination message for this. However, in the past it seemed that this termination message would only sometimes be returned to the user, and sometimes the message 'unknown error' would return.
Initially to work around the problem I would write the issues into an 'logged_items' excel and would return this to the user (using the data download service).
However it seems that the terminator issue is resolved in FME 2021.1, so maybe that could also help you out.
mgg_beca
Forum|alt.badge.img+20
  • Nov 14, 2023 7:45 AM UTC
I would love the ability to expose logger transformers to the app user while the app is running so you can log the results of specific processes. that way the user can see progress is being made. you could easily create custom error messages and log these as well. would be so much better than just thisScreenshot 2023-11-14 204025and then maybe something happens or doesn't.
  • Jan 22, 2024 8:47 PM UTC
Giving the specifics of a failure, or the output of loggers/terminators would be invaluable to users of flow apps. As opposed to a simple 'failed' message.
Often users are making simple errors with data inputs and parameters that is causing a lot of unnecessary back and forth. The majority of these issues could be self diagnosed with the ability to view these notifications. This is a significant issue for uptake of our developed apps.
LizAtSafe
Forum|alt.badge.img+26
  • Feb 10, 2024 3:59 AM UTC
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
ecx
Forum|alt.badge.img+8
  • Mar 31, 2025 9:48 PM UTC
This functionality would be extremely useful
for anyone looking for the workaround:
jclanton
  • Jul 22, 2026 3:24 PM UTC
Still a great idea!
oscarwillems
Forum|alt.badge.img+19
  • Sep 15, 2026 9:51 AM UTC
I have a “workaround” that works great for non-fme users:
  • (non)happy funcitonal flow: If I have a an error that I can catch, I stream back an HTML page with the error message packaged in a way that a non-fme user can troubleshoot.
  • Technical flow errors: then I have either the same HTML page if I can catch errors to contact the admin, or I have general instructions (usually the footer text rather than the description/prompt, since it stays visible after you press run) in the Flow App with a comment to contact the admin if something doesn't go right.
Because you assume the user that runs the app, can troubleshoot from a job log, but that is either a security risk, or an overload/red herring of information.
