In Development
Enhanced Sorting & Filtering in FME Flow Interfaces
Related products:FME Flow
  • Mar 28, 2022 5:48 PM UTC
  • 21 replies
  • 603 views
All the grids in FME servers are not sortable by users, sorting is the very basic function expected by all users from any software these days.
Please allow users to click on any column header to sort ascending/descending/removing sort for a given column.
The user should be able to hold the shift or control key to choose multiple columns to sort.
The sort function should work for all supported data types in the column, e.g. Number, text, date, user, etc.
LizAtSafe
Forum|alt.badge.img+26
  • Apr 5, 2025 4:41 AM UTC
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
LizAtSafe
  • Apr 5, 2025 4:45 AM UTC
LizAtSafe
  • Apr 5, 2025 4:53 AM UTC
LizAtSafe
  • Apr 5, 2025 4:55 AM UTC
bruran
Forum|alt.badge.img+9
  • Apr 7, 2025 4:45 PM UTC
​@LizAtSafe This idea does not seem to capture the same idea as the one I submitted, so merging it doesn’t seem to fit.  Being able to sort on a column is not the same as beign able to search (or filter) on a column.  If this idea is modified to include both capabilities, then that’s good (and better).  If that is the case, then please update this idea to include both capabilities so it’s clear.
However, if this idea is only going to include sorting, then please separate out my original idea for searching/filtering back to it’s own idea please, or let me know to re-submit it as it’s own.  Thanks for your consideration.
bruran
  • Apr 22, 2025 6:15 PM UTC
​@LizAtSafe Is there an update on my reply about the merge of these two requests that I beleive are two separate things?  Should I submit a new request or is the merged request being updated to include searching or filtering?
mark2atsafe
Forum|alt.badge.img+59
​@bruran I think it’s all going to come under the same project, from the Safe end of things, so that’s why the ideas have been merged. I was just in a meeting where we talked about the importance of both searching and sorting. I understand product managers are going to do a sweep through the ideas as well, updating the titles and making explanations where necessary, so they may have more info.
rylanatsafe
Forum|alt.badge.img+14
bruran
  • Jun 30, 2025 11:16 PM UTC
​@mark2atsafe ​@LizAtSafe Is there any progress on the search capabilities being addressed?  Have the product managers finished their sweep through the ideas yet?  Will searching and filtering functions be included in the product development plan, and if so, when could we reasonably expect to see it in the product?  Thanks for any insight you can provide.
rylanatsafe
​@bruran Hi there! Great questions and thanks for raising them. I’m working directly with the teams on this so I’ll step in to respond for ​@mark2atsafe and ​@LizAtSafe.
Yes, we’ve made progress on improving search and filtering in FME Flow. Our product and UX teams have completed a sweep throughout FME Flow to identify where improvements to data tables (e.g. search, sort, and filter) would provide the most value. We’re going to prioritize the most-used, high-volume pages—for example, the Completed Jobs page.
To set expectations clearly:
  • We do have a plan. Initial designs are complete, and development work is being scoped.
  • It’s not an “everything everywhere” update. Not all columns will become sortable/searchable—our focus is on usability, not complexity.
  • You can expect a larger batch of improvements in the initial rollout. These will be followed by smaller, iterative updates based on feedback and continued use.
  • Release timing? We’re aiming to start rolling this out in an upcoming release, but we don’t have a fixed date to share just yet. We'll do our best to keep the community posted.
(As an aside, I see now that I’ve created an automated link to a more specific idea, where in hindsight this idea may have been more appropriate to use—I’ll aim to reconcile that overlap once we have development scoped.)
nathanatsafe
nathanatsafe
nathanatsafe
Open→In Development
nathanatsafe
LizAtSafe
  • Oct 30, 2025 7:10 PM UTC
In Development→Open
ngoorman
Forum|alt.badge.img+3
  • Dec 17, 2025 3:23 PM UTC
Getting back into FME Flow since some years ago - my org is now publishing our first workspaces to our test deployment. We've set up an automation but I'm immediately struck by the seeming impossibility of getting a clear overview of when an automation will run. The main automations page doesn't tell me; if I open the automation and select the Schedule trigger, it just says ‘Weekly’. When is that - today, tomorrow, Sunday? I'm eventually forced to check its previous runs under the Jobs section to see when it was last triggered so I can extrapolate from there.
It looks like this was previously suggested seven years ago, so good to see it's finally being picked up. Main suggestions for the Automations page is the ability to see, for each automation:
  • how it is triggered
  • the iteration (daily weekly etc)
  • when it was last triggered
  • when it will next trigger
  • ability to filter/sort the above two items by day of the week, date, time, date/time range
nathanatsafe
​@ngoorman
Thank you for sharing your feedback—it’s great to hear that FME Flow is being reintroduced in your organization and that you have some fresh eyes on the product.
The specific suggestions you mentioned (e.g. showing how each automation is triggered, last and next trigger times, and being able to sort/filter by day or time, etc.) call attention to the need for more visibility into Automation and Schedule behaviour. That’s slightly different in scope from what we’re planning for this Idea, which is focused on adding basic sorting and filtering capabilities to existing table columns across the UI. I think some of the info you’re after would be brand new for the UI.
That said, I think your feedback here warrants some deeper exploration and could help influence future improvements to the "Manage Automations" and/or “Manage Schedules” experience. Would you be open to creating a new Idea post for this? That would make it easier for other users to find, vote on, and for our team to track and evaluate as its own potential enhancement.
Thanks again for contributing to the conversation, really appreciate it!
j.botterill
Forum|alt.badge.img+69
  • Jan 8, 2026 5:40 AM UTC
Hope FME Form can see some filtering and sorting love… and perhaps more ability to save layours
Please vote this one up: Visual Preview - Preset/Saved Column Selections | Community
LizAtSafe
  • Mar 11, 2026 3:20 PM UTC
Open→Gathering Interest
LizAtSafe
  • Apr 13, 2026 8:52 PM UTC
Gathering Interest→In Development
