Archived
FME Server 2016.1: MSSQL Server Repository with Windows authentication
Related products:FME Flow
  • Apr 28, 2016 12:00 AM UTC
  • 66 views
tino
Forum|alt.badge.img+28
If you want to access your FME Server repository on a MSSQL database via windows (integrated authentication) follow these steps:
  1. Follow the normal installation process for FME Server in combination with a MSSQL database
  2. Check if everything is working fine
  3. Give the designated Windows domain user db_owner privileges to the database "fmeserver"
  4. Stop FME Server
  5. Change FME Server Core service properties to run under the windows user
  6. Change the config in Server fmeServerConfig.txt" (the user and pw entry are meaningless)
  7. DB_TYPE=sqlserver DB_DRIVER=com.microsoft.sqlserver.jdbc.SQLServerDriver DB_JDBC_URL=jdbc:sqlserver://localhost:1433;databaseName=fmeserver;integratedSecurity=true DB_USERNAME=fmeserver DB_PASSWORD=$FME$1ser$ver DB_CONNECT_EXPIRY=60 DB_SQLSTMTS_PATH=C:/bin/FMEServer/Server/database
  8. Copy "<FMEServerHome>Serverfmesqljdbc_auth.dll" to "<FMEServerHome>Serverlibfmeutilsqljdbc_auth.dll"
  9. Restart FME Server Services
  10. (Optional) Delete the default "fmeserver" database user
steveatsafe
Forum|alt.badge.img+16
Thanks for sharing this Tino! I'm wondering if a code adjustment could avoid step 8...
Update
In FME 2020+ there is a second configuration file that stores the database credentials, \\Server\\ fmeServerWebApplicationConfig.txt.
You will also need to update the DB_JDBC_URL in this file to include 'integratedSecurity=true' and change the FME Server Application Service to run under the Windows user, or else you will encounter the issues recorded in this article.
