New
FME Inspector indexing
Related products:FME Form
  • July 8, 2026
  • 0 replies
  • 9 views
jeand
Is there any way to optimize the FME Inspector?
In my case, I'm opening a DWG containing approximately 600,000 features, and it takes nearly 7 minutes to open.
It appears that the Inspector indexes all attribute columns when the dataset is loaded. In some cases, I don't think this is necessary, especially when working with very large datasets.
It would be great to have an option to disable attribute indexing for large datasets, or even better, allow users to select which attributes should be indexed when needed. I believe this could significantly improve loading performance for large files.
Is there already an option to control this behavior, or would this be a good feature request?
Thanks!
