Open
FME Flow Server Name / Icon
Related products:FME Flow
  • Jul 15, 2025 7:57 AM UTC
  • 5 replies
  • 279 views
carstenotto
Participant
Forum|alt.badge.img+7
It would be nice to be able to give each FME instance an individual name (and possible icon) to be able to distinguish different instances without checking the sometimes cryptic or long url. Handling different stages in the same browser sometimes leads to tab change after tab change to get the right instance.
Different Instances of FME Flow
It would be possible to directly chose the correct instance if the admin defined name could be shown instead of FME Flow as title and possibly a selected favicon - that is already possible to change going into the webapp but not documented and the path may vary between versions.
rylanatsafe
Forum|alt.badge.img+14
New→Open
j.botterill
Forum|alt.badge.img+69
  • Aug 26, 2025 10:31 AM UTC
I recently added a broadcast message so i had some kinda of visual to help me distinguish DEV, TEST, UAT from the main Prod FME Flow.
Having a text watermark to the Flow icon would help too.
Also to rename the flow text (default page naming) would help. Edge helps me saved system username password credentials, edge://wallet/passwords but with multiple environments it seems to confuse saved flow creds.
Same user… different password… Edge gets confused
when the auto-fill is offered… the wrong password is interchanged
_jacques_
Forum|alt.badge.img+19
  • Aug 26, 2025 11:12 AM UTC
+1 on this!
I keep jumping between test and production environments at work, and some visual help would be great.
matthieuv
Forum|alt.badge.img+30
  • Aug 27, 2025 8:46 AM UTC
Thats why I have my test environment in Dark Mode and production just normal. But it would be a big help if you can do some customisation.
nathanatsafe
Forum|alt.badge.img+9
Idea merged into:
All the votes from this idea have been transferred.
