Archived
FME execution in Non-FME workstations
Related products:FME Form
pratap
Forum|alt.badge.img+12
I would like to suggest, if there is a way to provide small installation of FME such that it can execute workbenches thru command prompt or converting workbenches as exe files and perform translation.
This will help us to provide the workbenches to non-FME users.
sigtill
Forum|alt.badge.img+25
  • January 12, 2018
You should use FME Server or FME Cloud for this.
  • January 12, 2018
Agree with @sigtill. You can provide data translation services to non FME users via FME Server / FME Cloud.
revesz
Forum|alt.badge.img+22
  • January 15, 2018
If you have no FME Server or credit on Cloud but some floating Desktop licenses, the request may be valid.
If the user requirement is to run a workspace with known parameters, it is not necessary to set up the full Desktop. A minimal install option that excludes the workbench and other 'human requirements' is useful for non-FME users for whom admins can provide a shortcut/button to run the workspace they need.
Or at least an option not to create Start Menu/Desktop icons, integration, etc, if a minimal install wouldn't be smaller than the standard one.
jdh
Forum|alt.badge.img+41
  • January 15, 2018
You can run workspaces through the QuickTranslator.
It prompts for the public parameters, without allowing any changes to the workspace itself.
